Has anyone wired led lighting to the ACC terminals on the fuse panel ?
Im trying to find out if I could wire, lets say the right side of the bike to the one terminal and the left side to the other terminal (within specs of course).
Just make sure you get the positive wire from the LED's is connected to the positive terminal post in the fuse/relay box. the negative lead can go to the negative post in the fuse/relay box or a good ground on the frame. The 5 amps 60 watts available on the terminals is more them adequate for the LED's.
That would be the easiest location to wire your LED lights. I use the same terminal for my Doran TPMS.
i just ran my acc. lights and such to those screws on the fuse panel...the top is positive and bottom negitive...i then ran my wires to the 6 position fuse block and the negitive to my home made ground block and then run my relays from there for my lights ect...keeps the battery terminals clean and not so many wires to it...jeff
