Until it is " officially " stated that NO the 1500 windshield will not fit ( my gut guess also ), you might be looking into the F4 windshield. They have two options: F4 Plus2 which is two inches taller than the stock ( and up/down adjustable ) ; F4 Plus4 which is 4 inches above stock and not adjustable up/down because it is wider. If you are comfortable with looking " through " a windshield all the time, the Plus4 model will reduce the side wind buffeting with the added width. Unless I couldn't see them in your picture, the first deflectors you want to put on are those that mount under the mirrors. A little $16 item I like is the steering tunnel foam inserts. They plug up those gaping slots at the handlebar tree and add a quiet stillness to the center dash area. As always, start with the least expensive add ons and work your way up.
