Installed my new Windbender HP-S windshield on my 95 GL 1500. Dayle Martin aka Quickdraw at Fireceek Accessories was a great help as I decided to call him rather than do an internet order. Originally it was to buy one of his factory seconds with a 50.00 savings(I inspected the windshield and a very small scratch was visible at the lower edge of the base screen). He also sold me on the option of the springloaded pins at 39.90 as he said it was easy to lose the clevis pins which come stock with the manual system. And yes, I purchased the manual adjustment system, not the electric option. He asked me my height and I told him 5'8" as he said that the HP-S (I assume S stands for short) at 14" vs the 17". Dayle also mounted the spring-loaded pins for me which they normally charge an extra fee of 37.50 for installation which he did not charge. I also ordered the Dark Smoke tint for the lower half and bronze tint for the upper.
The Windbender HP is designed to see over the top as the front top edge of the windshield has a curved lip and creates distortion if viewed thru the screen. If an individual wants to view thru the windscreen or needs a higher windshield for a much taller passenger to avert wind buffeting, the ST is the one to get.
Delivery was quick as it arrived within a week and installation was simple and straightforward. I found the tracks a little stiff in sliding the windshield to adjust however a little wax made it effortless. The spring-loaded pins appear to be stainless steel, look professional and work well. I can adjust the windscreen from a seated position on the bike.
I found the lowest position to be comfortable for me for in-town riding and the twisties where wind buffeting is less an issue. At 75 it felt breezy but no strong buffeting as this setting will probably be my stock setting expecially in the Texas heat where I like allot of ventilation. At 95mph there was considerable wind buffeting at the lowest setting as I suspect if one were crazy enough to ride consistently at that speed a different adjustment would be required. According to their specs there's a full 3" of adjustment with the tracks and another inch at the mounting tracks at the windscreen. They recommend using the windscreen at the lowest setting of the Honda adjustable levers adjacent to the mirrors however I raised mine up to the highest setting.
I've yet to use the Windbender with a passenger to get their take on wind buffeting for them. I did find that at the lower setting, though it was breezy it was a calmer air and less noisy than my stock windshield which I had cut down. I felt less backpressure with this windscreen and could probably do without earplugs which I normally wear for touring. And if any of you are wondering from the pics, that is a Bike Barn that I store my Wing in.
Lower setting front
Lower setting rear
Highest setting front
Highest setting rear
Lower setting front
Lower setting rear
