Thanks Detdrbuzzard. I didn't know about the drains. I had water around the one plug, so I dried the plug then took them all out and put new ones in. I was thinking of making a weather shield to stop most of the water getting near the plugs.if you look there are drain holes for excess water. yours are probly plugged with dirt. a paper clip will clean it out
i had the same problem with my 1200 wing last year. my niece just happened to show up on her 1100 wing so i cleaned the drain holes on both wingsThanks Detdrbuzzard. I didn't know about the drains. I had water around the one plug, so I dried the plug then took them all out and put new ones in. I was thinking of making a weather shield to stop most of the water getting near the plugs.
