1 - 3 of 3 Posts
1984 1200
The engine vent hose thats goes to the water catcher on the left side of frame was full of water.The hose thats goes to the air filter, if you dont plug in to the filter lots of water,like steam comes out.Checked engine with block checker it showed ok.Pulled valve covers and they had lots of real white stuff inside not like when head gasket is blown.Anybody have this happen?
thanks david
crank case breather, the canister should be on the left side of the motor near the swingarm pivot. the tube goes in the top. flush and refil your oil too
I got it remove the little tank near the swingarm and remove the other plastic tank infront of the seat.Let the engine vent without them all is well now.
1 - 3 of 3 Posts
