jeff here in Sturgeon Bay, Wisc
I own an 82 Interstate.
Just picked it up and doing maintenance on it
One day while riding, the volts, which had been registering 14 or so dropped down to 8 on the gauge.
It has a new Motobatt battery...tested the voltage regulator...fine..tested battery...fine....tested three yellow wires...all three reading 65 volts...then cut connector, and spliced wires together......removed ground cable, cleaned and put back on
Bike starts right up......but with new battery, now reads about 11 volts and stays there,,,,regardless of engine RPM....In addition, which could be unrelated, the fuel gauge quit working.
It has a new 7 volt regulator too.
My question now...do i need to go to auto parts store to pick up a voltmeter and amp meter, and perform test as outlined in Clymer manual to verify alternator output
