1 - 10 of 10 Posts
bought this 1500 about a month ago, have only put about 1000 miles on it, runs good, and rides good, untill today noticed alot of vib when running above 65 mph, got home put bike on center stand, when rev the motor, in netural, above 2500 rpm start getting real bad vib, contunies to get worse as more rpms, any ideals what I might need to be looking at, thanks for help. :(
i have replaced the plugs, all filters, timing belts, because i didnt have any records. dosent seem like fuel related, but can never tell, it is a steady vib, not any kind of miss. It idles well, takes the throttle well, drives well down the road, It does shift hard, which i guess is normal for the 1500, thinking maybe in the clutch, sometimes it does seem as if the clutch might not be engaging when shifting gears as it grinds between shifts sometimes. but it does release and engage ok when you stop, so not sure if it can cause vib
Unless you have the service records from the previous owner there is a lot to look at, air cleaner, fuel filter, fuel pump, spark plugs, vacuum leak, carbs need to be synced. Start with the easy stuff first, plugs, fuel and air filter
Discussion Starter · #3 · (Edited)
carb sync should do the job
I would say check the drive shaft splines but you said it does it in neutral on the center stand so I think that would eliminate that.
Sounds to me like you may have an engine mount that has or is collapsing.Even if this bike is low mileage,age takes it's toll on this type of rubber part. I may be way off,but i believe worth checking,since you say the bike runs great.
Ah yes, another problem successfully solved by the brain trust of the Goldwing Owners Forum. Good job guys...
1 - 10 of 10 Posts
