OkIt could be something in the ignition system heating up and failing like the igniter
Go back. Check your kickstand circuit, then to kill switch assembly, then ignition switch components, ..........
No, I don't think so, he means Starting Fluid, sprayed near the hoses that might be leaking - the engine will pull in the volatile fluid through the vacuum leaks, and the RPMs will increase.
[/CITA]Starting fluid - Wikipedia
en.wikipedia.org
I do not know very well which hoses are those, if you make the return through the vacuum hoses, they would all be filled, right?
Sorry, I don't know what you mean by make a return through the vacuum hoses.[QUOTE = "Buenafuente1, publicación: 2250210, miembro: 76076"]
[QUOTE = "fossil92, publicación: 2250206, miembro: 1407"]
Haciendo la traducción veo lo que indicaste. ¿Probó la prueba del fluido de arranque debajo de la carrocería, como se indica en la explicación de JMartino ???
[/ CITA]
¿Te refieres al fluido de la bomba de combustible? , Hice una prueba de encendido cancelando también la bomba y falló lo mismo
[/CITA]
Yes, it only happens with a hot engine, when you say ignition coils do you mean the three spark plug coils? , Thank youThis only occurs when the engine is hot, correct? It could be bad ignition coils.
I insist the three? Can't something go wrong in front of them first? , Thank youYes, as they will break down when hot.
