The sticker inside the back box tells me the pressures should be 36 front and 41 rear. Can someone confirm that (generally speaking and with due regard to temperature) that those figures are correct?
I believe that is also the recommended TP in the manal. I'll have to go to the garage and check, but I think that is what I run on my 1800 with the stock tires that came with the bike.
... Howdy .... The Tire Mfg. Recommended Safe Tire Pressure And Load Rating Is Stamped On The Side Wall Of Every Tire ... Don't Go By The Bike Manual ... Happy Trails ...
The pressure in the owners manual is for stock tires, most people change tire types once the OEM's are gone. Pressure on side of tire is MAX air pressure, you don't want to run that all the time. For Dunlop E3's I run 38 f and 40 r
pc : variations are to be expected. 38/42 ( cold tire ) sounds fine. If you want extreme variations, ask what motor oil riders recommend ? Don't do it ! Just contemplate the possibilities.
I was confronted with the same question. When I picked up my '95 Aspy from a local dealer he inflated both tires to the pressure marked on the tires. The bike just did not handle right. I was convinced that the tires were over inflated. Note that the pressure marked on the tires states - - for max load. Therfore I adjust my tire pressure between the placard pressure recommended and the max load pressure as marked on the tire (cold). I do not ride 2 up and presently have no other load than myself at 155. Additional note my Dunlap tires are spec as OEM replacements!
