You’re welcome, yes you can just plug the new cancel unit in to see if it’s going to work without it mounted. The cancel function won’t work unless the bike is moving, but it should still activate the flasher.Rob , can't thank you enough. I ordered the part last night. Haven't redone all of the checks but I will. can I test the fix by plugging the cancel unit in or must I mount it? It is not over between you and me as I am in debt to you.I will post the results. Thank you for putting up with my marginal trbl shoot skill. Your last text was so spot on about how I had to be doing something wrong. Check those fuses and your test equip multiple times. My best advice,see you soon. Kevin
