Will run for 6-10 miles and then won't start for a couple hours. Will turn over but won't start. Has anyone had this experience? If so, how did you fix the problem?
You could have a weak main fuse that when it heats up it opens and when it cools it makes contact.
You could also have a bad pulse generator that gets hot and the bike cuts out and refuses to start. I normally test them with 'Freeze Mist' for electronics, when the component is good and hot I spray the questionable part with this and if the bike starts, I found the problem.
hello rvd, welcome to GWOF
What the other guys said; also, you may have a blocked vent in the fuel cap, try loosening the cap next time this happens, see if that makes any difference.
Welcome RVD. Any luck with your glitch?
Durk : head over to the member and say G'day to everyone. Welcome to GWOF. Eric
