I have tried about everything to disable the abs light on the dash of my GL 1800. I've tried pulling fuses, reseting sensor at speed ring. Does anyone have any other ideas that I can try to get that darn light to go out on the dash??????
Trikeman
Use the '******* Repair' method. Pull the bulb out of the indicator light in the gauge cluster. My buddy had a Ford truck the 'Check Engine' light stay illuminated on and he pulled the cluster and put black tape over the light.
Is the light flashing or just steady burning?
To extinguish the light without a lot of work just snip the Y/Bu wire coming from the ABS controller to the gauge cluster and the light will be off.
The wires for the ABS controller and the controller are under the tupperware in the front of the bike. It should be in the vicinity of the air cleaner in looking at the component call out on the line drawing. I have a service manual on CD that I'd like to give to you, it's not doing me much good, as I prefer hard copies.
