I'm not looking to do this..not anytime soon anyway, but, I'm curious; If you have a late model wing w/ABS..will that work with a trike kit? Or, will you loose the ABS?
If you are thinking of triking-check your "crazy" import laws in Canada.
Seems something is amiss that won't allow you to register a conversion "imported".
Not clear on the whole deal, but think the "kit" has to be installed in Canada.
Some posts from a gal whom can't get her Stallion registered on the
Trike Talk forum.
On the DFT you transfer the ABS set up to the kit and it uses the OEM set up.
CSC Trike Conversions:
Disc Brake System
Truly masterful engineering went into the design of California Sidecar Trike's COBRA disc brake system and the result is truly confidence-inspiring braking performance. The brakes are completely integrated with the O.E.M Linked Braking System and we are the only trike manufacturer to offer full ABS integration.
Proprietary, patent-pending, CNC machined four-piston aluminum alloy brake caliper
11.5 in. purpose-designed cast rotor.
