1 - 2 of 2 Posts
· Registered
I have checked thevcold tire pressure on front and rear several timeswithb three good presure guages. The are 36 and 41 on the dot. However the TPM light flashes for abour 2-3 miles on a cold start then stops flashing. Whats going on with it? :confused:
· Registered
The TPMS is set for around 4 lbs low alert if I understand it correctly. Mine said that they preset is at 40 PSI so if yours is the same then your 36 PSI tire is setting the warning off. If you bump it to 38 or more that should fix it. The reason it goes off after a few miles is that the tires heat up and the pressure increases. I know you know that but I felt the need to go there, LOL!
1 - 2 of 2 Posts
