1 - 20 of 20 Posts
· Super Moderator
there is nothing in my shop manual or owners manual telling when to replace belts but a friend i trust changes his every 80,000 miles or eight years. he said he would not go past 100,000 miles on belts. my belts on both wings are going to be changed soon
· Banned
82' Interstate question
I have had my 82 GL 1100 for 4 years now, still just 39,000 on the clock. I read in another thread that if the belt goes it can take the engine out. I have no real idea how old the belts are. They could be original? I bought it from the 2nd owner.
What is my best course of action here? Change em' on GP?
Thanks for any advice.
· Super Moderator
well they told you right buzzltyr. if a timing belt goes the valves will contact the piston. mine are being changed as a precaution. the guy i got my 1200 from said he didn't know if the belts had been changed and the guy i got my 1500 from only got it himself because he knew he could resale it and make some money so he doesn't know anything about the bike so belts will be changed
· Banned
Thanks Detdrbuzzard!!
Are you going to do the job yourself? Any idea of shop costs? I also read that while a technician is in there he might as well flush and clean the radiator (needs a special mityvac tool or something) and then there are some other rubber seals or something that should be changed on gp at that time. I'm still learning about this...
· Super Moderator
another friend who has a small shop is going to help and show me how to change the belts. i will flush the radiator, change the thermostat and hoses at the same time. i've been told to add the coolant slowly to keep from creating air pockets in the engine but no special vac tool. pm sent to you
· Banned
The GW motor is an interference motor. So the valves will hit if the belt breaks or slips. I would not call that it would "take out the motor." If that were to happen, you would have to pull the head/s and replace the damaged valves. Chances that a piston would need to be replaced are pretty slim. I have seen MANY piston to valve "arguements" and the piston always wins! The only time I have seen pistons needing replacement is when a valve head breaks off and sticks sideways into the piston. Even if you get a good "ding" in the piston, you can debur the edges and leave it alone most times.
Hey detdrbuzzard, I am in Royal Oak. Maybe we can meet up some time?
Tom
· Super Moderator
i am free most weekends tom and welcome to GWOF. check your messages
· Registered
hi guys. just from my experience in 34 years of GW work, gl1000s,gl1100s, an gl1200s have broken timing belts in as little as 47,000 miles. we've only had two gl1500s with broken belts and both were around 100,000 miles.
· Super Moderator
Does anyone know the NAPA part number for timing belts for a Honda Goldwing 1200?
250070 napa, 5043 or t070 gates or 40070 goodyear
· Registered
I'm planning to change my belts also, I have 93K on my 87 Aspencade.
I'm restoring this bike that I bought Jul 10 09.
The previous owner rode it to my place about 125 Km. mostly hyway So, it runs just fine,but I'm nervous about the belts.
It looks like the rad needs to come out? Also, if I don't move the cams in any way...can I just replace the belts the same way they come out?
Or will the timing need to be set anyway? Thanks for any help...
· Banned
Actually , the Nakedgoldwing forum has discussed this at length .
I am only familiar with the GL1000 , but in that case , you can get at the timing belt covers without removing the radiator .
Drain the coolant , remove the lower hose flange from the block , remove the 2 lower radiator mount bolts , loosen the 2 top mount bolts . Now you can get at the bolts that hold the covers on .
( 2 bolts each ) A 10 mm short socket and 1/4" air rachet really helps .
If you have crash bars , you may have to loosen or remove them , especially on the right side , to get the cover to slide out .
Take plenty of digital photos before you start taking the belts off.
Unless you take off the valve covers ,and back off the valve adjusters , the cam wheel will jump off the marks as soom as you remove the belt .
Follow the procedure in Tech Tips .
The left belt will go on and line up pretty easy. The right belt will never quite line up exactly on the mark . When you get it to look like it's off 1/2 a tooth ABOVE the mark , then you have it all set .
Remember , this is only true on my 77 GL1000.
your experience may be different .
· Registered
Insurance and peice of mind....
Got my bike for Fathers day from the wife...Bought it from a elderly gentleman...he clamed at 98k the belts were changed...at the dealer..... he clamed he brought it there and told them to servise it and check it out becaus he was going to sell it ....tune up,lof,new altonater, back brakes,and timing belts......well today she has 105k and I changed the oil,plugs,timing belts and added a triger wheel and there is no way the belts and plugs were done at 98k.......new bike do them it is the best insurance you could get....
· Super Moderator
I have a 1993 and the belts were never changed and as the second owner of the bike and the age the belts were changed, interesting things one was beginning to delaminate (come apart). Just like the post above says it best. Better to be safe than sorry.
· Banned
Rule of thumb with a new to you Goldwing change the fluids and the timing belts , then you have a known starting point, Just my opinion
Timing Belts
GL1000 & GL1100 (requires 2)
Honda part #14400-371-04/14400-371-14
Gates #T274
NAPA #250274
Goodyear Gatorback #40274 (AutoZone & ??)
GL1200 (requires 2)
NAPA #NBH 250070
Gates - #5043 or #T070
Goodyear - #40070
GL1500 (requires 2)
Gates - #T275
NAPA - #250275
Goodyear - #40275
· Registered
I just had the belts changed on my 1997 GL1500 with 40,000. I figured they were 13 yrs old so I better change them. However, the belts they took off looked really good. Even the seals looked good.
No cracks or fraying at all.
1 - 20 of 20 Posts
