Will have to get a better pic, not much time standing in the middle of the turnpike, got what I could
Anyway, I ordered the Bushtec hitch and isolator relay from Wingstuff, dropped shipped from Bushtec, I went with the Bushtec hitch for the 6 point mount. Everthing was perfect but they forgot to include the pin lock, had to call for that and a bike side wire harness, the isolator has a factory plug instead of loose wires. I was worried about the install, debated whether I would do or let the dealer, been reading reviews and such, but the instructions were spot on, pictures and all. The install went very easy and when I did need an extra hand my 5yoa grandson was there to help
. Didn't have to loosen or move the mufflers to slide in the hoops. 2 "headaches", lining up the upper supports and that nut on the right side lower subframe, but even those weren't too terrible, centering the thing was probably the hardest thing to do, had to find a suitable reference.
Wiring not tough either, although the instruction for the plug and play in the top box was backwards, I unsoldered 2 connections before I found the mistake
I intend to email them about that.
All in all, not nearly what I thought it was going to be, total job time (with dinner and straightening out the wiring) about 4 hours. The thing seems to be rock solid, and fits perfectly, seems to be a well engineered hitch, wouldn't hesitate to recommend to others
