1 - 10 of 10 Posts
If I recall correctly, the tank on a 1500 hjolds about 5.2 gallons.? Tonight after work, I put 5.21 gallons in it.:eek: I have about a 35 mile ride home from work, and when I left work tonight, the gauge read below empty. But I figured what the heck, even tho I was getting horable milage on this tank, I figured I could still make it home. I did, but was cutting it close!
when the low fuel lite on the dash comes on you have one gallon left in the tank. i find that when the needle is on " E " there are two gallons in the tank, atleast with my 1500 wing
Ditto......
It's when your tank takes 6.4 gal that you realllllllly are on the edge....
If you want to check to be sure your low fuel light works & to see how far you can get on a tank. Do what I did.
Put a 1 gallon gas can in your trunk, fuel up reset the mileage & ride, ride, ride. I did it the fuel light came on, I kept riding, riding finally fueled when the odometer hit 228??? I believe & figured then I knew. Always at least fueled when I hit 200 after that & never really looked at the fuel guage again.
It's good to know your normal range to the final sputter, just remember that every day is different so it's not a given that it will always be the same.
1 - 10 of 10 Posts
