The numbers are the same for all Wings 1/2" pre-load on Voyager.
80% of air suspension capacity.
20 psi Voyager tires.
0 psi front fork air assist.
Process to set unit:
Only 20 psi on Voyager tires. (Make sure that motorcycle rear air shocks are at 80% capacity. Normal tire pressure on both motorcycle tires.)
1. Tools needed: 3/4”, 7/16”, sockets or wrenches and a torque wrench.
2. Loosen the (8) 1/2” U-bolt nuts. (If you have the
old style suspension lock bar you will, also, need to
loosen the (2) 3/8” lock nuts on the suspension lock bar using a 9/16” socket or wrench.)
3. Remove the 1/2” Short Shock Tower Bolts, nuts, washers, spacers completely from top of shock and shock tower.
4. Roll motorcycle rear tire onto 1/4”, 1/2”, or 3/4” preload plate.
(Make sure motorcycle is in first gear when tire is on top of preload plate.). The more preload the less lean you will have with the motorcycle inside the Voyager Kit.
5. Now tighten the (8) U-bolts to 35 ft. lbs. (torque wrench is needed) (If you have the old style suspension lock bar you will, also, need to tighten the (2) 3/8” lock nuts.)
Reinstall short shock tower bolts, washers, nuts, & spacers and tighten completely.
6. Now you are ready to ride again.
