I have a 93 Aspencade and I can't get the rear suspension to pump up. The fuses look good and I wondering if there is a way to check if the pump is bad before I put the money into a new one. Or if there is anything else I should check first. Thanks for any help.
Hey jhoth!
First, does the pump/compressor operate when you push the button(s)? Second, if it does work, any leaks in the sytem, including the rear shocks themselves?
put the bike on the center stand, turn the key to the on or acc position then press the increase or decrease button. the buttons can stick from lack of use
Doc's got you pointed in the right direction, if that doesn't help try to give a bit more info as to what you have done to this point.
Welcome to the site.
I think you have to push check pressure and increase buttons simultaneously.
Can you here the relay click when you try to increase the pressure, and can you get any air out of the Aux air line in the right saddle bag.
You can try some Radio Shack contact cleaner on the switches, besure to flush the switch well with the cleaner.
Welcome to GWOF. Looks like they gang has some ideas for you to chase, good luck.
