1 - 10 of 10 Posts
My stoplights don't work. I checked the fuse & relay. Both OK. Still no stoplights. Any ideas ?
check the bulb and clean the sockets too
Are they inoperative with both hand and foot brake?
Discussion Starter #4
It's connected to the trailer and all lights work except the stop lights. Bulbs OK.
What happens if you disconnect the trailer?
Did you try swapping out the relay?
Discussion Starter #8
Yes ... I disconnected the trailer . made no difference. No, I haven't changed the relay. But it does work.
Jim O'D.
Discussion Starter #9
Tail lights
I found the problem The previous owner had fitted a "black box" that made the tail lights flicker three times before going solid. I threw it out and went back to standard.
All OK now. Thanks for your help.
:Wave:
Jim O'D.........
Tail light flasher for safety, when they work...
Glad you found the problem.
1 - 10 of 10 Posts
