Hey ray, guessing its the tach. My 82 and 91 tac weirded out a couple times. Had the cables replaced, end of problem. Try pulling the tac cable off at the tac and putting some oil down it
Might help.
Good luck and ride safe,
Strat
Dirt and grime can cause the problem with the cable. Once it rotates enough it frees itself. Try oiling the cable or using something like a graphite grease if you can take it off.
Here is how I did mine, although it wasn't sticking. Disconnected at front wheel, removed from various cable holders, and then suspended the end high above tac with string and oiled it and left it hanging there for a while. Note did not disconnect from tac.
The gauge movement may be dirty and need cleaning.
Related Threads
Honda Goldwing Forum
511.5K posts
21.4K members
Since 2008
