The PO of my NTM 97 gl1500 (32,000 miles)told me that he had had 2 episodes where the bike wouldn't start. He said both times he bump started it and everything was fine. He couldn't offer any insight as to the circumstance that brought it on.
So today it did it to me. The lights dimmed when the button as pressed, reverse light wouldn't come on-(neutral light was on before I tried reverse) but no start action and no reverse.
Remembering a 58 Ford I had that would have the starter lock up occasionally, I put it in 4th and rocked it backwards a few times. after 3 attempts, it started perfectly.
Thoughts? do I have a starter problem, solenoid problem,relay problem, reverse problem, gremlin problem or ??
TIA
Check connections and check relays for the starting circuit. Intermittent electrical problems are always fun to find. The 'B' relay.
There is a large solenoid (A) forward of the Battery that has been known to to stick. A Canadian friend of mine had his stick on a trip and shorted across the terminals to start his. Might be your problem. If your starter is not turning at all.
How old is the battery?
From the Northwest Corner
Ron
