You said the starter works when you hook it up directly, and you can hear the relay clicking. So, unless there is a problem with a connection between the relay and starter, (should only be 2, the one at the relay, and the one at the starter), then there can only be 2 things wrong I can think of. First, check the ground on the starter. If it is not cleanly grounded, all the juice in the world will not make it crank. Second thing that could be bad is the relay. You hear it clicking, that means that the magnet is pulling the points in. That does NOT mean that the points are any good. What you can do is take a jumper cable, and go from the + side of the relay to the starter side of the relay. That should make the starter turn over. I did have a freind with a GW and he had a similar problem. Bench tested the starter and it worked, but the motor would not crank over. He asked me to look at it. I put a test light on the starter and hit the start button. The light came on. I then put the light on the + side of the battery and touched the starter, it lit, so the starter was grounded and getting juice. Sol I did what any experienced mechanic would do with the data I had. I wacked the starter with a rawhide hammer hard. That was all it took. There was a bad spot on the commutator, perhaps carboned or oxidized, hitting the starter disrupted the oxidation or carbon or what ever and it cranked. I then let it crank as long as I was comfortable I could without killing the battery, (kill switch in kill), I did thid to "clean up" the commutator. It has been a couple of years, and no trouble since then.
Tom
