1 - 20 of 23 Posts
1981 GL 1100
When I started it yesterday the starter just stopped
Now all i get is one big CLICK at the solenoid
I took a jumper wire from the hot side to the bolt on the starter and nothing but a spark from the wire touching...no spin no nothing
could it be anything else besides the starter?
Discussion Starter · #6 · (Edited)
Is this the original starter from 1981?
It may have finally quit.
I am 99.5% sure it is the original, the bike only has 34k on it
I changed the timing belts 2 weeks ago and the were the original Honda belts
It turned over yesterday for just about 4 seconds and then just stopped, and then nothing but one big click at the solenoid. but starts fine on a roll off
Shouldn't starter spin/engage if i put a jumper wire on starter? it does nothing
Also u cant here a click at the starter but if you put you hand on it u can feel it the BIG click "sound" is at the solenoid
I did notice twice last week when engine hot, if i shut bike off and then tried to re-start right away the starter would drag REAL REAL slow and wouldn't start the bike... I would have to roll off . But when cool it wouldn't drag
Have you taken the starter relay out and bench tested it?
How old is the battery?
I'm going to scan a diagnostic flow chart and will post it shortly.
battery is fine and charged
starter relay? same as solenoid ..the thing in the boot beside battery?
I touched the two bolts with a screwdriver and it didnt turn the atarter
starter relay? same as solenoid ..the thing in the boot beside battery? Yes.
See flow chart and starter relays test page.
If you go from the hot leg (the heavy red one from the battery) on the starter relay to the starter side of the relay and make an outside connection the starter should turn.
Lowes, Home Depot, Radio Shack and Harbor Freight have test meters. It depends upon how much you want to spend and the degree of accuracy.
Discussion Starter · #12 ·
I took jumper cables and the battery from my boat
Hooked the cables to the battery and Grounded the Neg side good to the bike frame
then touched the hot to the starter post and got nothing but a spark
did not spin over at all or make any sound other then the spark
Discussion Starter · #19 ·
OK
got the starter off...was easy as pie didn't have to drop exhaust or take off gear shaft like all site said
took it apart and the 2 sprockets were busted missing teeth on both it was locked up
i didn't have a drop of oil come out...i saw one site that said a half quart world pour out
It's sad you cannot just buy the planetary gears, you have to buy the entire starter.
You'll be better off with a new one.
1 - 20 of 23 Posts
