I have an '83 Aspie that I purchased knowing that the starter clutch needed work. I tried the Sea Foam in the oil trick, but it didn't make any difference, so I pulled the engine. The starter clutch was clean although the rollers were magnetized somewhat. I replaced the rollers, pins and springs and put it back together. I know the rollers were loose because I had to pin them back to get the clutch over the journal. So I put the engine back into the bike enough to try turning it over and the thing still won't work. The starter just spins away. Anyone had any experience with this happening? I think it's highly unlikely that it's the starter, but I do have another starter kicking around. Is there any point in trying to change starters?
