1 - 3 of 3 Posts
My 82 interstate when I start it up and is warming up, it goes pfft pfft once in a while. like a plug or coil stops firing (I have never had this before) . This eng has had all the mods and belts done recently, adj carbs not valves yet.Eng has always ran great and does not smoke at all. I don't want to start getting into it until I get a second opinion . once It warms up its fine. I used sea foam a couple of months ago and a few weeks ago changed fuel filter. I wonder if I should re adj carbs after the sea foam,thats probably it . Hopefully some one has had this problem .thanks for you help tedmass:)
Sorry Ted can't help you out. Once you figure it out please share with us.
Tedmass,
Is it a "Putt" or a "Pfft" sound? If "Putt" it beats me; if "Pfft" (misfire) double check your ignition connections, including plugs. (Did I actually just write this? Guess it's time to go to "A Home"!:D)
1 - 3 of 3 Posts
