1 - 3 of 3 Posts
sometimes the pad is not sliding across the pins like they should and that will cause a squeal too
Brake pad composition will cause this along with a half dozen other things...not servicing the slides and pins/bushings or even just dust build-up in the pads.OEM pads are the least likely to squeal and work the best IMHO,but the calipers and mounting pins need to be properly serviced no matter what pads you use.
1 - 3 of 3 Posts
