I have a 1989 Wineberry red GL 1500 and would like to find some spray paint for a touch up project. Does anyone have any ideas as to where I could locate some paint for this job ?
The paint code is on the inside of the fuel door, take it to your local body shop and they should be able to mix some up for you.
LSC try this: http://www.colorrite.com the code is R114CU. You could probably have any custome painter or body shop mix it as well.
color rite is the place. I repaired a friend's honda and also bo't clearcoat.
It came out great. they claim they mix paint for auto co's if I remember right.
If you take a small part into a high end auto paint store they should have a colour scanner there. The scanner will give the exact mixing instuctions for the colour and can account for aging. They can mix it and put it in a spray can, this is a bit expensive this way but it allows for a novice painter to paint parts and get the colour right. The scanned is about 98-99% accurate and something I use regularly when I'm painting cars. Good luck
