The speedometer issue, is probably the cable or the drive gear located at the lower end of the left fork by the axle or the cable. Remove the left rotor cover locate the Speedometer cable and unscrew it and pull the cable out of the sheath and inspect it. Also remove the drive gear unit from the fork/axle (one philips screw), and inspect it. If you have to replace either the gear or the cable , I would replace both get the cable and a new sheath, if the cable is bad the sheath is more then likely damaged.
The cruise control is speed sensitive, my guess is if the speedometer is not working the cruise won't set.
From the Northwest Corner
Ron
Ron
