I installed speed bleeders in every spot possible on my wing this morning (clutch, front and rear calipers, and anti dive valve, 8 total). The initial work of getting the clutch slave and the front brakes took the longest. Then I did it in stages,
1st replaced the clutch slave bleeder screw and flushed the system,
2nd replaced the 2 bleed screws that are operated by the hand lever, then flushed and bled at the same time
3rd replaced the 5 bleed screws that are worked with the foot brake and flushed the system
this made it soooooooooooooooooooo easy, it is now a simple one person job
put the hose over the bleed screw, clip hose in old mayo open screw, pump brake until clean fluid, close her up....done
I do believe I am going to order them for my truck and my wife's car... so I can single handed flush those two as well
I am running out of projects
