Honda doesn't publish hp and ft/lb numbers for any of their bikes since there is no standards for data presented
. We had the figures supplied by a member in another post here just the other day, and the numbers on trike lady's vid are close. The video shows more torque (about 10 lbs/ft) and the hp is down by about 5 but doesn't say where the tests were done (altitude, barometrice pressure etc affects dyno numbers) and different dynos give different readings because of calibration. Gross hp and torque specs that I've found on vairous web searches run around 117 hp and 123 lbs/ft
. Oh and I think Dookoo's having a bit of a go on you (purely in jest of course)
OK, here ya go, post #8:
http://www.goldwingowners.com/forums/showthread.php?t=9411
