1 - 2 of 2 Posts
I have a 2008 gl1800 I get leaves, bees and all sorts of stuff.I have it to the dealer and they could not find the problem. i also called Honda and they were no help what so ever. Does anyone have an answer for this?
There is a big gap at the bottom of the dash panel where it goes around the speakers, put your fingers in there from under the dash and you can feel it. You could put some foam in there to stop the stuff from getting in there, most stuff that gets in there will usually fall back out, if not just raise the dash panel and they will fall out. It just pulls up from by the key area. No tools required, and you don't need to take it all the way off either, just lift it enough so the stuff falls out.
1 - 2 of 2 Posts
