I've been looking all over the net for information about removing the seat on my Goldwing. The owner's manual gives no info. Can anyone tell me how or where I can find out how to remove the Wing seat? I'll be installing (or having installed) a Utopia backrest and this call for seat removal.
Will appreciate any info on which Honda manual shows a description of how to remove the seat. I'm not very good with mechanical things but I wan't to know how to do this.
Thanks In Advance,
T-Rex
It's also easier off and on if you open the trunk lid, remove 2 phillips head screws securing the passenger back rest, close the lid, remove the back rest by pulling up.
Also, if you have the Comfort System, don't forget to unplug the seat and passenger back rest before you remove them completely.
Don't forget to plug them back in! Don't ask why I'm telling you not to forget the plugging back in:D
I disagree, all you have to do is remove the screws holding the passenger hand rails, open the trunk, pull the seat back then lift the front on the seat to clear the tank plastic, lift up then disconnect the seat heater plug, (if equipt )
Re install it in the same reverse order. I have had my seat off several times. It is the easiest thing you will ever do to your wing!
Seat comes off easier than putting the key in the ignition!
Thanks for the tips. I haven't tried this yet but will be doing so to install my mp3 player.
Discussion Starter · #6 ·
Seat Removal Gold Wing
Thanks for the all the post concerning the seat removal process. I've copied all the posts and will pass them to the man who will install the back rest.
Thanks Again,
T-Rex
I have never gotten my seat off with out first opening the trunk.
I gave this a try and agree that opening the trunk makes the process easier. It creats a gap where the very back of the seat can lift up into, giving more room to slide the whole seat back to disengage the front tabs. Then the seat pivots up and comes out easily.
For any of us that plan on doing much dismantling and farkling on our bikes, the Service manual is worth it's weight in gold (and the sucker's pretty heavy). Clymer are OK, but the Honda manual is far more accurate, although it isn't perfect.
