1 - 2 of 2 Posts
I want to know how to wire my rings of fire on my 1800 goldwing? Or does anyone have some picture instructions on this!
Depends on what you want, you can do it several different way. You can wire them to a switch so they only come at night or when you want them on, you can run the wire up the forks and slice them into your turn signals, your signals are dual filament so find the right wire, you might also be able to wire them as running lights and flash with your turn signals. I had the front fender accent on my 08 and wired them as turn signals. You can see the wires going up the forks
1 - 2 of 2 Posts
