When I was on Vaction,I was talking to another Winger and he told me If I wanted to get 20 thousand miles off my front tire. Just to change the tire rotation Someone told him about it,So he Had his frt new tire put on in reverse Direction And said he has no problems . Has anyone heard about this or tried it??
We noticed that alot of Crotch Rockets rear tires were rotated,
Directly from the AMA website speaking of tire reversal. I would not try it myself, but to each his own...
Rotation and balance marks
One of the more critical marks on a motorcycle tire is the rotation arrow, or arrows. Today's specialized tires generally have a tread pattern that must go in only one direction. Some manufacturers even state that their tread patterns are designed to disperse water, and by mounting the tire backwards, they won't work.
The other big reason for noting wheel direction has to do with the manufacturing process. The tread rubber is initially a flat strip that's cut to length, at an angle, and then spliced together with the two ends overlapping, creating a hoop. Under acceleration, a tire mounted backwards will try to peel back this splice. The opposite is true for the front wheel, where directional forces are reversed under hard braking.
Discussion Starter #4
I dont think I want to try it, Life is to short
Maybe he was talking about putting a tire designed for the rear on the front. Several do this when running a car tire on the rear of 1800's. This is done, as far as I can tell, to have a tire on the front to last as long as the car tire on the front. I have a car tire on the rear but I stuck with a Bridgestone 709 for the front.
he had the rotation turned on his frt tire I saw the arrow going the wrong way
I am not disagreeing with you. I am just saying it may have been a rear tire put on the front. In this case a lot of riders mount it in reverse. The arrow will point the wrong way.
The big problem is water displacement, the tread is designed for best traction and water displacement. Unless you mount it yourself I don't think you will find a shop that will mount it backwards, liability reasons. Keep an eye on the air pressure and balance and you will get great mileage from the correct tires going the correct tires on your bike.
I haven't looked yet but I figured that on a tire designed for the rear wheel (which provides traction) might be point the opposite of the front tire which don't get traction. THIS IS WHEN BOTH HAVE THE ARROWS POINTING THE WAY THEY ARE SUPPOSED TO. Therefore if you put a tire on the front that is manufactured for the rear wheel you would have to put it on the front backwards to get it to disperse water like a real front tire. Course the maker probably wouldn't be liable for a "rear" tire put on the front.
Ditto on what Joe says about liability, and what was posted about the tyre manufacturing process. I have no problems with riders doing the 'darksider' thing with the car hoops on the rear, bur I like the built in cornering advantages of a 'real' motorcycle tyre. I have seen alot of custom darkside applications, and they look pretty cool, just isn't my cup of tea. I'm neither an engineer or a manufacturer, so I prefer to believe that those that are know far better than I what really SHOULD work best.
