1 - 15 of 15 Posts
I really have no use for the radio antenna and would like to remove it. Removing is the easy part but does anyone know of a plate or cover that would fit flush against the trunk so I could remove the base as well?
How about just some plugs to cover the holes in trunk?
You might consider using the larger Chrome snap caps and screws or bolts. Don't know of anything that would fit flush.
From the Northwest Corner
Ron
Donald,
If you kept up with the "what tools do you need" you know that the list eventually included toilet paper as a required tool.
I didn't make this up, I'm just replaying it.
So you're wondering, "what the hectic does this have to do with my thread".
Well, as near as I can determine, space is a prized commodity and I am thinking this is actually a TP holder that doubles as an antenna. Might want to reconsider.
Ever the resopurceful one L2R! Donald, you don't use your radio at all?
Discussion Starter · #10 ·
Budoka I don't use the 'regular' radio at all... can't stand it. I have satellite radio in both cars. Still in my trial period for XM on the Wing and I may/may not sign up... still undecided.
Come on Don. Get one of those short black rubbery antennas. It just wouldn't look balanced without something pointing up in the air. Like a cat without a tail.
Discussion Starter · #12 ·
Chopin I never really thought about it that way. I must say, after I laughed for about 30 seconds non stop, all inhabitants of the household staring at me, I came to realize that this object may not only be a radio antenna but might also function as a gyro-flux-hyper-balance correctional device. I may have to reconsider!
no don you have to leave the stock antenna ( s ) on otherwise you'll have nothing to get caught on the garage door when entering or exiting :)
1 - 15 of 15 Posts
