I went on a 800 mile trip last weekend and noticed a burning brake smell a few times. This has been an on going issue even after it passed the recall. The rear rotor is wore, were as the front rotor looks almost new(27k). I took out the upper rear slide pin and cleaned it and put fresh grease on it, could not see another slide pin.When I active the front brake lever it does NOT engaged the rear brake, I thought these were linked?
I talked to the dealer and he said a little drag is normal, but should it be wereing the rotor? He won't be able to look at it until first of the month because of bike week down here.
I did notice the rear master cylinder was just over the full line. If I move the rear caliper around, doesn't move much, it stops dragging.
Any ideas on this?
Thanks
Any ideas on this?
Thanks
