Rear Axle
1919 Views 2 Replies 3 Participants Last post by  Sempai
Hi I'm new and I need help. I have a 1978 GL-1000 and I need to replace the rear brakes. How do I get the rear Axle off? I took the nut off of the left side but how do i pull it out? I have the tire lifted already and the bike is supported. Any help would be greatly appreciated.
Thank you.
1 - 3 of 3 Posts
try lifting just the tire up slightly to get the weight off the axle
You've removed the axle's nut on one end. Go to the other end, look for a PINCH BOLT. Even with the weight of the tire, you SHOULD be able to pull that sucker out.
1 - 3 of 3 Posts
