1 - 2 of 2 Posts
I own a 1983 GL1100 Interstate and on my way to work this morning i noticed that radiator fluid was all over my right leg and the side of the bike. when i stopped there was coolant everywhere and from what i can tell it appears to be coming from the cap but im not sure. should i buy a new cap? or a whole new radiator? or can i use radiator leak stop additives?
I would not recommend using any additives. Could be a bad cap or pressure buildup in the radiator, pump. You might also check for a cracked hose.
1 - 2 of 2 Posts
