Are you looking to just remove the radiator cap only??? Cap is located under Right side storage area on 2001-2010's
Ronnie
Just looking to install LED strip in the cavity.
oopps thought you were looking for the radiator cap........Sorry!Just looking to install LED strip in the cavity.
This is awesome... thanks a lot ... It helped a bit... was able to get the wire run through back of the bike to front panel. so all good.here is some info from a Honda Repair Manual for 2012-2013
View attachment 274299 View attachment 274300 View attachment 274301
and this on a website
2013 Honda GL1800 4AC COWL | Babbitts Honda Partshouse
Shop online for OEM COWL parts that fit your 2013 Honda GL1800 4AC, search all our OEM Parts or call at (231)737-4542www.hondapartshouse.com
hope the pictures of the manual can be made readable
from it.............lots of digging
The whole manual.... for sure..if you think the manual info will help, let me know.......... for I can make a copy in pdf format at work on Monday and load it up
I can copy the entire body work removal section
