1 - 14 of 14 Posts
So I have a new (to me) 82 wing interstate. I am planning on going thru it this winter to find things that could be updated. And I was hoping some of you seasoned wingers could point out some things that could be updated.
I have been around bikes most of my adult life and so I kinda know what to look for. And I have the tools to do just about any thing on the bike. but I was hoping for more bike specific things.
I am gong to re due the front fork seals. I didn't notice and front bearing head shake before I took the bike off the road. But I was planning on looking at the head bearings. I am also going to put new belts on. And I will be changing all of the fluids and the break pads too.
I also heard about the main connector on the wire harness for the stator that it needs to be looked at and possibly hard wired to avoid the stator from prematurely failing.
So are there any other suggestions that the seasoned wingers might have that would be a good upgrade. Keeping in mind that I am not into all that fancy chrome and dodad's that some people want to add to the wing. Stuff I typically add are purely functional things like extra fuss box, extra break lights.
So all suggestions are welcome and thanks in advance for your words of wisdom
Dave D.
Dave, Welcome to the forum from Pa. Since I've got an 1800 I'm not much help to answer your questions, but there are a number of early Wing riders on here that I'm sure can help. It's good that you are handy with the tools. As for me, I think I know where mine are.... maybe. Ride safe and enjoy the forum...
You've pretty much got everything covered, you may want to lube the cables and new tires if they haven't been replaced. Replacing incandescent bulbs with more efficient LED's in the running and brake light circuit. If your Wing has a 7" diameter headlamp you can upgrade to LED's there also.
but you have a stator which puts out 100% if its power all of the time and while you may save a watt by going with led lights the excess electricity produced by the stator is converted to heat by the rectifier. and and hello dave, welcome to GWOF
If you're thinking about adding a pair of 55 watt driving lights and other lights to enhance visibility, LED's are the way to go for the other lights. Charging systems aren't very big on older bikes and you have to do a 'give and take' with lights. I had a 1988 HD Bagger and I had to crunch the numbers when I added lights, it ran both LED's and incandescent bulbs.
It was actually easier to change the bulbs then to get into the engine and change out the charging system.
Hello and welcome to the forum. It looks like you have just about everything covered. I would put some Seafoam through it.
Welcome along adecooda! Good folks and info here!:cool:
Seafoam is a addittive you put in gas. My boat mechanic told me about it. He told me it doesn't get rid of water ,it just helps burn it.you can use Seafoam or Stabil. Welcome to the forum.
seafoam can be added to you oil before doing an oil change to clean the gunk inside the engine
Dave D.
Hi Dave, welcome to the forum. Enjoy your new ride. I had a 82 GL1100 before this bike for a few years. Great dependable bike. All I did was the usual maintenance.
Discussion Starter · #13 ·
help from my new friends
Thanks for the Sea foam suggestions. I typically use Stabol for the same reasons that you suggested
Larry in Seattle thanks for the suggestion on the tires. I was think of replacing them for the same reason. Better to be safe than sorry running down the highway 300 mile from any ware.
Thanks for your suggestions
Dave D
Welcome to GWOF from Maryland
1 - 14 of 14 Posts
