1 - 20 of 41 Posts
Questions about F6B
Hi guys, I'm new here, thanks for having me. I'm going to upgrade to a new bike in January, and I'm seriously considering a Goldwing. I don't know if I want the GL1800 or an F6B. I'd like to test drive an F6B, but I can't find a place to ride one! I'm in Houston, and none of the dealerships stock them, so I guess if I wanted one, I'd have to order it. But I need to see if the seating, footpeg, and handlebar position are comfortable. So, do any of you guys have an idea that I might be overlooking about how I can test ride an F6B?
I've been test riding the DCT GL1800 lately, and I like the bike, but I know I'd need risers for the bars, as I stoop forward a little to reach them. I currently ride a Shadow, which has a much more laid back and relaxed seating position. I know that there are riser and sweep kits available for the GL1800 that look like they would solve my problem nicely, but I don't know if I want the DCT transmission. I already know that if I don't go for the DCT, I definitely want an F6B instead of the GL1800. In my opinion, the F6B is a much better looking bike. So I need to know how it fits. I've also been test riding Harleys, and I like the Road Glide, but I get the feeling that the F6B deluxe offers much more bike for the same price, so if I can find one that works for me, I'd rather buy it.
Another thing I noticed is that I can't flatfoot on the ground on the GL1800. I sat on a used F6B at a dealership, and it seemed that the seat was lower to the ground, despite the fact that Honda's website says the seat height is greater on the F6B. Unfortunately I couldn't test-ride the used F6B that I found because it was on consignment, they wouldn't let me.
Also, if I have the same problem with the F6B; if the bars are slightly too far forward, is there a riser kit that will bring the bars of the F6B up and back a little bit, without breaking the bank?
Thanks for sharing your knowledge guys.
So just for discussion sake, the F6B ended it's production run in 2017. It may be difficult to find a dealer that will allow a test ride on one if it's a new leftover. What may be easier is to find a privately owned one that someone will allow you to test.
The F6B was replaced by the Goldwing. The Goldwing Tour replaced what we all knew as the GL1800. Even though the new bikes are still GL1800's. Both the Goldwing and the Goldwing Tour come in Standard 6 speed manual & DCT versions with a 3rd model on the Tour that includes ABS. The ABS version though only comes in DCT configuration.
Hope this helps somewhat?
Oh and Welcome to the GWOF from PA.
Discussion Starter #4
Interesting. So the bikes listed on Honda's website are leftovers? Have they been sitting in a warehouse since 2016? If so, would you buy a bike that's been warehoused that long?
https://powersports.honda.com/street/touring/gold-wing-f6b
Thanks for the advice.
Eagle Rider in Texas may be able to hook you up and you can rent one. https://www.eaglerider.com/ They do have locations in Austin and San Antonio.
Good lead, but I don't see any F6Bs around here. Thanks!
Discussion Starter #5
I found one to test ride, it's a couple of cities over, but worth the drive to see if it fits me. Thanks for the advice.
It was mentioned that production has ceased for the F6B, but it looks like they can still be ordered from the website. Does that mean that those bikes have been sitting in a warehouse since production stopped? Would you buy a bike like that?
If the 2016 satisfied all of my wants and needs, yes I would definitely buy it. Deeply discounted price compared to a current model and ,if its unused or even used as a demo the dealer is selling as new, a full "new bike" warranty beginning with the mileage on the odometer. If it has everything you want, why not?
Discussion Starter #7
Just to clarify, you don't think sitting in a warehouse for a couple of years would be harmful to the bike, or in some way reduce its lifespan? Forgive me, I'm not mechanically inclined.
The only things I would be concerned with would be rubber parts that are exposed to sunlight. If the bike has been stored indoors (humidity controlled would be best, but I doubt any dealer is going to spend that money), then the only other concern would be tires. They have a life span of approximately 5 years, regardless of mileage or how its been stored. You can look at the sidewall to see when it was made. Even a tire that has sat on a rack for two years with wrapper still on, its already lost 40% of its value. So for that you might want to consider bargaining for new tires. But still check the mfg date even if the dealer gives you new ones. Discreetly, you don't want to insult the guy.
All good advice from Randy.
Discussion Starter #10
Great advice!
One more question, then I'll give you guys a break.
On Honda's website, it shows the F6B available for "build." When I select the options, it then shows me a list of local dealers I can get a quote from. That is clearly an indication that Honda has some left, and will ship them out, right? I hope it's not a website issue, only to find that they're not really available. Also, it shows an MSRP of $21,499. That's obviously not what I'll pay, right? What kind of discounts do you think I should expect for a 2016 year model bike?
Thanks again guys.
I think of you find the right dealer that could be a significant discount. Maybe not so much if they have to get one from Mother Honda but if in fact they have one in their own stock.
As far as the options I would think those too may only be limited. However the aftermarket companies would no doubt have more availability.
I think if I was doing this search, I would probably contact dealers, get comfortable with one, and then get busy on a deal.
Gosh, Fossil, I gotta show this to my kids.
Discussion Starter #14
Guys, I've got another issue I could use advice on. I test rode the F6B and a 2019 GW Tour back to back today. My dilemma is that I like the F6B better, but I get crazy head buffeting with the low windshield. The windshield on the F6B was aftermarket, and looked much taller than the stock F6B windshield. The aftermarket windshield on the F6B was just the right height, according to what I've read online. I could just look over it. The GW DCT windshield eliminates all buffeting for me at its highest setting. I could get the F6B and just get a really tall windshield, but I've been told I should not use a windshield that is tall enough that I have to look through it. With the 19 GW, I can move it up and down, but there doesn't appear to be any adjustment in the F6B windshield. I was under the impression that the windshield could be moved up manually on a standard 2016 Goldwing, but I couldn't find out how to do it on the F6B. Is the windshield adjustable on the F6B the same way as a touring GW?
I like the F6B a lot better, even without all the fancy features of the 19 GW. But I've got to find a solution to the killer head buffeting. It feels like my head is in a paint shaker. I have the same problem on all the Harleys I've test ridden as well. The ONLY bike I don't have head buffeting on is the 2018/19 GW, because it's the only one that has a windshield that goes over my helmet. On bikes that don't have a windshield at all, I have no problem, other than being tired after short rides from fighting wind, but no buffeting.
This head buffeting is not something I could just deal with. I don't know why, but my head buffets so bad that it blurs my vision. I've tried multiple Harley baggers with 2 different full face helmets, and a half helmet, same problem. My friend has a Street Glide, he says he has no problem, but I ride his and I have a headache after 10 minutes. It even happens on the road glide. Maybe it's because I'm a big guy, and displace a whole lot more air or something, I don't know, but it's killer. I'm telling you, I'm not just being a pansy about it, it blurs my vision so I can't read road signs, and gives me a headache.
I've seen videos that show the 2016 GW windshield being pulled up and down, and quite a good bit. I need to know if the F6B can do this. Also, would you ride a bike with a windshield that's so tall that you're always looking through it, not over it? I've always been told that's a safety issue, but that seems to be the only way I can ride without buffeting.
Any advice you can provide about aftermarket windshields, or your experience with GW windshields would be greatly appreciated.
Here's a video I took of the test ride of the F6B and the GW. You can clearly see the shaking I get with the F6B compared to the 19 GW. If you're watching on your phone, you probably won't notice, but on a computer screen you can definitely see it, and hear it. And that's with my camera's strongest video stabilization feature! That sound you hear riding the F6B is not just the mic, it's my freaking helmet shield rattling from the dirty air.
there is several things that the F6B didn't come with compared to a standard Goldwing. So adjustable windshield is probably one of them.... since it came with a little short stubby thing.
As far as riding a bike and looking through the windshield. I had a 98 GL1500SE that had an extra tall windshield, I am 6'2" and at its lowest setting I still had to look through it. For most days that was absolutely not a problem, no worse than looking through a car windshield. On rainy days, to me it was a god send..... you did not get wet other than your hands.
The bad days were on the chilly , humid mornings.... so as you go from top of hills to bottom the temp changes so much that the windshield fogs over abruptly, and since there are no windshield wipers, that did cause some concerns some mornings. I just stuffed a micro fiber towel in the cup holder and reached over and wiped the top 4 inches on the front and what ever I needed to on the inside...... not much different from driving my old 1950 GMC in which the heater was more of a warmer, maybe, defroster...haha not even, and wipers ran off of vacuum so going up hill, didnt have them either.
So I found it to be no big deal.............. just clean it right so you don't put lots of little hazy scratches in it... then the sun will glare.
after now watching your video.... the F6B DOES NOT have windshield adjustments.
IF it did, there would be a lever just to the outside of each speaker, that released the tension so it could be pulled up or pushed down.
Discussion Starter #17
That's good advice, thanks for the perspective. I feel a little better about getting a high windscreen. The rain didn't cause a visibility issue?
I keep my windshields cleaned with Pledge Multi-Surface, followed by McQuires Quik Wax
It works as good as Rain-X, the water just beaded up and flowed up and over, only issues was if you got up close behind a car,,,, the tire spray is so fine that it didn't want to bead up as well.... same in heavy fog.
But again, I didn't find it any worse than if you had the same thing happening on your face shield.
If the windshield had been freshly waxed..... no problems at all, then it didn't take long in fog, to get enough moisture on the windshield for it to start to bead up..... once that started..... it cleared itself reasonably well.
So..... actually...... if I know I am fixing to ride into some rain on my now 1800.... if I have a place to do so.... I pull over and raise the windshield to its highest position...... I have to look through it...... especially if it hasn't been long since I cleaned and waxed it
Discussion Starter #20
Cool, that's a big question answered. Thanks sir for sharing your info, we new riders need it! I only wish I hadn't waited so late in life to start.
1 - 20 of 41 Posts
