1 - 10 of 10 Posts
Happy Spring Everyone! Late last fall I purchased a RAM mount assembly for my GL1800's Garmin GPS. Finally started to get things underway for the riding season. How do you attach the RAM-B-309-1, Ball/Double holed shaft part to the handlebars?? The part has a rounded/depression on the shaft to accomodate a round handlebar. With our wings we have a more square situation...I don't want to place a chrome C-clamp...There should be some kind of adapter...Any help will be appreciated!!!
I have a spare Garmin 2610 and want to fit to wing , Can someone help me out , Thankyou
I believe Ram Mount makes a monting system that will work on your 2610. Go to their website and you should be able to find what you need. You will also need a 12v connection to power the GPS or else you will have to run it on it's battery and recharge everynite.
http://www.ram-mount.com/
If you need Ram Mounts, the best place to get them in my opinion is www.gpscity.com They have every mount known to man and good prices and super fast shipping. I have ordered tons of Ram mounts from them and recommend them highly. If Ram makes it, GPSCity has it.:D
I have ordered the clutch bracket for Goldwing , it should be here soon , changed the oil , not used to so fine a oil in bikes , My usual is 20/50 for the BMW which we all know has been around since the war lol , Many Thanks .
Do not take off the original brake lever mount, just take out the existing screws put the new mount with the two spacers and the longer screws right over the existing mount....I hope that explains it.............
Most of the RAM mounts I've seen go over the cover instead of replacing it.
There's one here that can accept 2 balls for mounting.
For more ideas, just google "ram clutch cover mount"
Reactions: budoka
What NVSB4 said above. Just be sure to get the replacement screws in tight enough. I nearly had a disastrous leak when I did mine. Only my little handy mini socket set save the day and my bike's tupperware form caustic/costly brake fluid damage...:surprise:
1 - 10 of 10 Posts
