Added Fiamm low-tone horn, but no relay. Will the world end because of that?
I picked up a Fiamm low-tone from Pep Boys today; 4AMPs; bent the bracket some to get it to fit, but it works like a champ. The stock low-tone one was no longer functional. I did not install a an inline fuse and relay, though - just hooked to stock wiring. I assume the 15amp horn/turn signal circuit can handle it. Am I correct?
Also, noticed on the way into work today at 65mph on the interstate the sound and maybe even the volume were anemic, yet at 45mph around town, it's plenty loud enough. Then I figured it out... maybe... these horns work like speakers via vibration. Yes, there is a thin aluminum/pot metal protective element in front of the horn, but the horn itself faces the front of the bike. So that when I'm traveling 65mph, I'm inadvertently pushing wind against the horn/speaker element, muffling its sound... or at least that's my story. The hard shell horn covering you get on some horns would go a long ways towards rpeventing wind force from stifling the speaker... I mean horn
