1 - 13 of 13 Posts
Going to change rear tire on my 03 wing for the first time and was wondering if you can get the tire off without removing fender or bags.
I am getting ready to do mine for the first time. Depending on model may only have to remove the back fender and stero amp to pull the tire out while on center stand. If on a jack you don't even have to do that. There are a lot of guys that lay the bike down on the engine & bag guards on the right side and remove the wheel. Once laid down you have to raise the wheel a few inches and extend the centerstand to hold the wheel in the air while you remove the lugs. I would like to break loose the lugs while the tire is on the ground and sidestand to avoid strain on tranny (probably wouldn't hurt anything in the first place) but looks like it is going to be hard to get to the lugs while on the sidestand. Mabe someone else can give us some pointers on how to best break the lugs.
A number of guys on another forum have used the technique that Chopin has sent you. Remember if you lay the Wing over you can't have highway pegs attached to the engine guard. You need to remove them first so the Wing will lay on the crash bars. Good luck and ride safe..
looks like the lay down method from the you tube video is a good way to go.Will probably use this method. thanks.
I recently changed my rear tyre, I put a 4 x2 under the feet of the center stand (to raise the bike by 1.5 inches) and lifted the bike onto it's center stand. Then removed the rear mudguard panel (5 bolts on my 2003 goldwing) with the number plate attached. I was then able to undo the wheel bolts, slide the wheel out the back and get the tyre changed. The bike was very stable stood on it's center stand and block of wood and it was surprisingly easy to do. The hardest part is trying to get the bike on it's center stand with the piece of wood underneath!! after that it's childs play..
If I had a tire already mounted on a spare wheel I would do the lay down method. But I would hate to have in in that position if it takes a long time to get to the shop for them to mount a new tire.
lay down the bike,2x4???? i just changed the rear tire on my 2005,put on center stand,put in 1st gear,removed fender back & rail,took off lugs ,tilt the wheel on angle & roll the wheel out the back.
Hello Bobby. I have an '08 and they keep talking about part of the sound package being a pain to remove in order to get the wheel out while on the center stand. Supposedly that is the reason for laying it on its side. Did you have to take out an amphifier or anything like that to get the tire out?
Discussion Starter · #11 ·
Just an update on changing the rear tire,laid the bike on it's side as the video shows,no need for a jack or taking off the rear fender it was real easy after getting through the idea of laying your bike on it's side. thanks Chopin
Yes they recommend only having a small amount of fuel in the tank. I am not an 1800 guy so don't know the exact but something tells me I remember seeing less than 1/2 tank.
The least amount of fuel the better when laying the bike over. Not trying to chastise you but I'd never let a tire get that far gone.
1 - 13 of 13 Posts
