1 - 13 of 13 Posts
Hey everyone just trying to find out why my 85 Goldwing Aspencade is running rough or it seems not to be firing on the front two cyliners. Her is what I know so far. I bought the bike in June 2011 and had no problems. Then it seemed to start spuddering in 1rst and 2nd gear. then I thought that the carbs might be dirty so I used a can of Sea Foam with a tank of gas. Then it seemed to be running better then all of a sudden I was riding for about 40 minutes around 22 miles, then I stopped for a couple of minutes shut off he bike then I got back on and started the bike and took off then that is when it started. It was like it was running on two cylinders. WOW! I had to ride back 22 miles. Could use all the advise I could get Really don't want o take it to a shop but if I must I must. I am pretty much mechaniclly inclined. Thanks and God Bless for all the Help.
Could be your coils as you have two of them and one controls the front two cylinders and the other the back two. Check your spark plug wires to make sure they are making good contact.
Another thing is fuel. Did you pull the plugs to see if the cylinders are firing. If plugs look ok then check fuel side. Filter, check fuel pump pressure, etc etc.
I'm going to say it is a possible electrical problem. Electrical connectors being the first place to look, clean the connectors well and use dielectric grease on them, make sure they fit tight. Check grounds for loose connections and make sure there surface is clean.
How old is the battery?
Could be the pulse generator. I had to replace mine. I think there is a test for it. If you have a manuel it should be in there. If you don't have one.....get me a bit and I will try to look it up for you...
If Bama doesn't get you the info, PM me and I'll look it up on the dealer site. Your plug leads/wires/caps could also be the culprit so check them for current as well.
Yes, the pulse generators go bad and to test them you'd check them for resistance.
Between the wire pairs White/yellow & yellow for #1&2 cylinders and the white/blue and blue for #3&4 cylinders. The resistance in the coils should be between 1,100-1,300 ohms @68 F.
Ok thanks. I really dont want to sound ignorant but the wires which to test for the resistance is the two wires on the back of the coils RIGHT. And How to you PM on this forum site?
The wires are alongside the ones for the stator on the left hand side of the bike under the same cover as the battery. When you undo the four place connector you want to test the pulse generator side.
Sorry Jayman for not getting back to you. I have the electronic version of the 1200 manuals and I was trying to send one to you but the file is too large. I tried to zip it down but it still was too large to send on here. You really need to invest in a paperback manual if you can. I have seen them on ebay. It tells you step by step how to do the test for a non starting engine and it has pictures too.
1 - 13 of 13 Posts
