I ahve a 95 1500a with turn downs on the tail pipes. Before I start cutting, how do I remove the tail pipe from the muffler? Do I drill out the welds an pull it off? It has spot weldsom the pipe and muffler.
I'm not sure so I can't offer any sound advise. Do you have a shop manual for the bike. It may show the muffler assembly and if it actually comes apart. On the 1800's the tail piece is screwed on with a silcon adhesive to seal it. Good luck.I ahve a 95 1500a with turn downs on the tail pipes. Before I start cutting, how do I remove the tail pipe from the muffler? Do I drill out the welds an pull it off? It has spot weldsom the pipe and muffler.
