Well unfortunately, here I am. I have a 1986 goldwing adpencade 1200. Picked it up for pretty cheap and of course there is problems.
Siphoned out the old gas from the tank, added 2 gallons of fuel and 1/4 can of seafoam. Put new fuel filter on as well as new spark plugs. Did all this just to start with knowing the bike sat for 2 years.
After I was able to get it running with the choke, it would idle fine sorta, if you give it 2% throttle it would stumble and get really rough, get the throttle past that then it will allow you to get to higher rpms fine. Trying to take the choke off, it will die immediately. Just had it running about 30 min with choke and still trying to slowly release choke, it will do the same. Was told it needed atleast 20min to warm up with choke on but still same problem.
Now, if I have it reved up to say 2000, then I am able to take choke off slowly, but there is more problems with how it sounds. Sounds like some loud knocking on the right side of the bike (while sitting on it right side). Let go of the throttle and it dies immediately.
I assume it needs carbs cleaned due to not staying running without choke. But I've also heard about alot of ignition problems with these bikes. Would love to get some help and insight on these problems from you guys who know way more than I about these bikes.
