1 - 11 of 11 Posts
... before the battery goes dead. I was told these bikes have a very hot starting system. MY mistake is that I fail to realize that I've inadvertently hit the 3-position kill switch and try to start it a few times. By the 4th try (sometimes the 3rd) the battery doesn't have enough juice to start the bike. Unfortunately, I let the batt run down 2 or 3 times now not realizing I left it parked in a key position that engaged the battery - difficult to tell in bright sunlight.
I'm trickle charging my battery tonight to ensure it can fully charge.
Does 3 or 4 tries sound aobut right for these bikes? Any ideas?
Get a gel cell battery and don't look back. It takes a good battery to start your bike and a good battery will help keep your alternator in good shape.
If you think about it a 1500 or 1800 has the engine close to what is found in small cars. Then think about the battery in those cars and you will see why a m/c battery will not crank as long. Best thing I have found is a "battery tender" which I always keep attached to the Wing whenever it sits. Keeps the battery fresh and ready to go.
PS.. Next time check the kill switch....lol
Discussion Starter · #4 ·
I know it sounds silly - the kill switch, but it's very hard to see that is on on/off. Most bikes it's a rocker switch, which makes it easier to know when it's engaged, visually speaking. And it's difficult to get into the habit of checking it since I never use it - even when turning off the bike after a ride. I've got some old habits to break :)
first check your battery to be sure none of the cells are weak or dead and that its full of water
Sounds a lot like a battery issue to me. I found my 1500 would crank "okay" and the battery would not last very long if the bike didn't start right away. When I had it checked, I found the battery needed to be replaced. After I put in a new battery I realized how slowly the engine was turning before it started AND how much longer the battery would last if I had a brain fart and forgot the kill switch position. I would take a real good look at the battery before anything else.
A 1500 should start on the first or second try. The battery should also be able to crank it for one or two seconds several times without slowing down.
If you are going to go with a battery tender device, get the Honda OptimateIII. It has a full refresh and desulfating capability that will easily add years to your battery life. I use it on my sleds, bikes and RZR, even my lawn tractor. Works wonders:cool:
get the odyssey battery and you won't need a battery tender just disconnect the battery for the winter and reconnecit it in the spring. i have had an odyssey pc680 in both wings for three years now and nither battery has ever been on a charger
1 - 11 of 11 Posts
