1 - 17 of 17 Posts
Morning, what is everyone using as their perfered digital map when it comes to route planning? I wont bother to go over the one way conversation I had with my computer when trying to use Google Craps. Thanks.
I use google don't know what your problem encounters have been but it works for me. I know my pal in Va. uses Yahoo.
I use any and all available sources, but haven't found much difference in one or the other. Mostly I research by State and City the things that interest me and then plan my route according to traffic patterns ( even times of day or night ) and fuel availability along with available lodging, which can be done pretty much on my GPS.
Discussion Starter · #4 ·
Morning, the issue I had with Google was that I knew I wanted to take the "round about" route , not the most direct route. I would place a marker at cities for tracking time and distance and it would change my route to go back to the most direct route. I had the settings on to avoid HWY and no Tolls. It just seems that it could have let me create a route for user preferance? no such luck.
Try following these directions. I found the same issue you had but then this helped. Not the easiest but it works.
http://www.goldwingowners.com/forums/showthread.php?t=9333
Consider this a semi hijack:hijack:....The folks around know a couple of us Southern boys like the covered bridges and I couldn't help but notice your Avatar. Where is that beauty MSG?
Thank you, I'll go back and give it a go.. you guys are so smart. I should have signed up to this group a long time ago????
Hey Ref another guy that we Buffaloed......:icon_smile_tongue:
If it doesn't quite work MSG. Send me a PM & we can try to work through it.:3dcool:
Discussion Starter · #9 ·
Hi Jack away, it is Just south of Thomaston GA, on HWY 19, Auchumpkee Creek Covered Bridge. Im in Senoia, so if you guys put a ride together let me know. We border hop alot.
Hey MSG, Ref & I'm going to include Crownfire because I know he does this as well.
An Ole Fossil just realized an interesting observation.
Southern Boys (GA,AL, & MS respectively) gauge directions, rides, & locations by Covered Bridges.
N.E. Guys (PA,VA, & MD) gauge these things by Breakfast & Ice Cream Stops.
:ThumbsUp::WellDone:
Hmmmm, only 400 miles from my place Phil......sorry for the continued hijack.
Oh, I use google map and adjust the route by letting it pick first then just moving it to roads I would rather use. Then I copy regular highway maps and highlight the route I want. I have an aftermarket gps on the bike but mostly use that as a rolling map to see where I am.
This has potential.......One more bridge for my collection.:chopper:
To stay on topic.....I have the Garmin that came on my bike. I can bust my routes up and get better results.
I like the honda planner, because of the ease of use, and the fact that I can down load the route to my Zumo GPS, store it on line, or on my lap top.
I also use a large Michelin Atlas 2013 for planning. Harley also has an atlas that shows selected routes for motorcycles.
I've been using mapquest.com for 1 or 2 day trips. I like that you can "drag" the default route to some other road that you want to explore. I've never tried googlemaps. Is it mo bettah?
I find it easier to use but what ever you are used to working with. Sounds like it works like google maps.
Google, Maplandia, Mapquest, just about anything that pops up on the screen. I ain't fussy....
1 - 17 of 17 Posts
